RCU Forums - View Single Post - Tiger Moth pull-pull question.
Old 11-09-2002 | 01:24 AM
florida817
Default TM Rudder bar
Hi Dave,
The full scale Tiger Moth has a simple one piece rudder bar, pinned in the middle, that is longer than the fuselage is wide and actually protrudes through a slot in the covering on each side of the fuselage. The rudder control cables attach to the bar outside the fuselage.
My 1/4 scale Clark Tiger Moth appears to have the same mechanism until you look inside the cockpit. There is a separate short bar for each side. It is pinned in the middle with a screw and is free to rotate. The outboard end connects to the rudder cables, the inboard end (inside the cockpit ) to the rudder servo pushrod. The rudder servo sits in the center of the fuselage about 3 inches behind the two short rudder bars.
Hope this helps.
Tom
