RCU Forums - View Single Post - Tiger Moth pull-pull question.
Old 11-09-2002 | 01:37 AM
Tmoth4's Avatar
Tmoth4
Default Tiger Moth pull-pull question.
Here's a tail shot showing how I have the cables running. The upper elev cables run through an eyelet on the leading edge of the stab. The full-size has a short bar that runs through the eyelet with the cables attached to each end of it.
I used braided nylon fishing line for the rudder cables because I didn't want to have parallel metal wires (possible RF noise). They have held up just fine on a 1/4 scale plane. I used the cable that Balsa USA sells for the elevators. If yours is a smaller plane the fishing line should be OK for everything.
Jim
