RCU Forums - View Single Post - mac conversion
Old 11-17-2005 | 07:20 PM
jetski_waxhead
Default mac conversion
ok here are some pics of my engine i am doing for my airboat
i was unhappy with the bottom of the engine so i desgined a new base for it and turned it up on the 3d mill
I will now make one out of alloy since i am happy with the base also it makes it alot easier to mount the engine as well
The taper on the front is for the starter and the piece on the back is my prop tool but i am not happy with them at the moment
I will make a cdi ignition for the engine and mount it off the bolts you see on one side of the engine
i removed some of the cooling fins to make it look better as it going to be in the middle of some serious airflow anyway
The clear adaptor at the front is to shape the air into the carb and this was designed and made on a 3d mill as well
ID:	356000   Click image for larger version
ID:	356001   Click image for larger version
ID:	356002   Click image for larger version
ID:	356003   Click image for larger version
ID:	356004   Click image for larger version
ID:	356005   Click image for larger version
