Thanks for the tips! The previous owner had the regulator a turn and a half proud of the body... I've set it flush and the leaking has slowed WAY down... Plus the engine is running great! I've run two tanks of fuel through it and it really sounds good.
Now if the weather would cooperate I'd take the UCD3D out for its maiden voyage!
I do have one other question... not sure if this is the correct place for it, but here goes: Can you recommend a good Tach? I have a Magnum Digital mini-Tach and it seems more like a random number generator than a tach!
I'll have the engine full throttle and it'll read 1700 then I idle it and it reads 2300... and I have to put it so close to the spinning blade to get it to read something other than 000 that it worries me... I'd be grateful for any recommendations...
Thanks again.
Bobby R
