RCU Forums - View Single Post - RichModels Works LTC ARF's
Old 11-17-2005 | 09:26 PM
cjackgo
Default RE: RichModels Works LTC ARF's
Mine's still under construction too. It's to bad the instructions are so crappy. [:'(] I'm guessing the crome rod installs just in front of the engine? What is it there for?
Did the CG come out right without adding "additional" weight?
I will join the majority of you and install an OS 46 also. Question, am I correct in assuming that when the cannard elevator goes up, the plane noses down?
If nothing else this should be totally different than anyone flies at my field.
Jack
