RCU Forums - View Single Post - Schultze Charger Problem
Old 11-17-2005 | 10:04 PM
JSF-TC's Avatar
JSF-TC
Default RE: Schultze Charger Problem
On the Schultze, you cannot set the sensitivity, only the battery type. I have it set to NiMh.
Also, the 4hr charge time limit cannot be altered. Only when the charge rate is set at 100 or 250mA is the time limit not imposed.
Setting the max charge level to 99999 will not have any effect as the timer will still cut in at 4hrs.
I'm going to run an experiment with back to back tests on the same pack with my 330 and my Super Turbo. I have cycled a new 2100mAh 5 cell NiMh 3 times at 200mA on my Super Turbo and both times measured a discharge capacity of ~2000mAh. I'll try both chargers at a 2A charge rate and 1A discharge and see what results I get.
Thanks for the suggestions so far.
Paul
