RCU Forums - View Single Post - MVVS 91 rpm's...
Old 11-18-2005 | 12:04 AM
DarZeelon's Avatar
DarZeelon
Default RE: MVVS 91 rpm's...
RAMZ,
DON'T YOU DARE EVER TRY RUNNING 'CRUEL POWER', OR ANY OTHER ALL SYNTHETIC IN YOUR MVVS.
Your engine needs fuel with 20% oil, at least half of which is Castor.
There are commercially available fuels that have this oil content; PowerMaster GMA and Sig Champion, for example.
If you use the 'fuel' you intended to, you may not immediately ruin your engine, but it will run very badly and you will void the warranty and you will never be able to hide this.
...Your plane will stay clean...
Do the break-in as described in [link=http://www.rcuniverse.com/forum/Tapered%2DBore_Engine_Break%2Din_%2D_Upgraded/m_1850473/tm.htm]this RCU thread[/link] (you will be adding some degummed Castor to the oil package).
I cannot give you an exact number, but you would expect 8,000-8,500 with this prop. It is pretty large in the usable prop range for this engine. The 15x6 size is more appropriate, I believe.
The #3255A silencer will not reduce the RPM by very much in this low range.
If this prop reduces RPM considerably, it places the engine below it peak torque and this can cause overheating.
