RCU Forums - View Single Post - removal of prop on OS46
Old 11-18-2005 | 12:34 PM
bruce88123
Default RE: removal of prop on OS46
JohnW's method sounds great. I never thought of an intentional hydraulic lock. Clever. If that doesn't work, use an old tooth brush handle or other soft plastic stuck in the exhaust port like delman suggested. You may need to whittle down the handle a little to fie in far enough to block piston travel.
DO NOT USE METAL UNDER ANY CIRCUMSTANCES IN THE EXHAUST PORT.
