RE: removal of prop on OS46
Hi Mr. Genius. Thanks for asking! Nope, not quite finished. I had been debating on putting a YS-110 on board, but the waiting time for those engines is a bit out of reality so I am going to continue and stick with the Evo 100.
Progress so far.. well, I had to fabricate a servo tray.. don't know what happened to the one that came with the ARF, but that was no big deal. I have the main gear installed, wing completed (with servo's installed), elevator, rudder hinged, tail wheel installed, one half of the pull-pull run completed. What remains is to put the elevator and rudder control horns/arms on, then finish installing the servo's and the other pull-pulls, the engine throttle, canope, cowl, then go over it one more time to make sure I didn't forget anything, then adjust all, or check adjustment for throws and so on, then it's maiden time.
I would imagine, if the weather holds out, I will have it airborne after I return from the Thanksgiving weekend in Massachusetts with my mom and brother.
DS
