RCU Forums - View Single Post - Which brush less motor?
Old 11-18-2005 | 01:43 PM
raz54
Default RE: Which brush less motor?
ORIGINAL: Nitronutt
Give me the prop pitch, battery voltage, pinion & spur teeth (If it is geared) and I can plug it into a speed calculator that I have to see an approx top speed for you.
The prop is 25 mm (1 inch) and pitch is 1.58, 7.2 volts. motor KV is 4200, direct drive.
