You have access to the broken prop hub I take It? Use those channel locks to hold on to the prop hub not the aluminum hub because you will bend it or at least nick it up pretty badly.
DS.
If the aluminum hub breaks or bends from holding it with channel locks you will be in a world of hurt when it heats up from friction and you are flying 300 feet in the air ! GL
