RCU Forums - View Single Post - RichModels Works LTC ARF's
Old 11-18-2005 | 07:28 PM
cjackgo
Default RE: RichModels Works LTC ARF's
Thanks for the info.
I'm not sure what negative thrust on the nose wheel is. As I understand it, you lowered the front end? By how much?
Did you have to add more weight to the front end than the "brick" that comes with the kit? Good advice on the full tank balance. On a standard aircraft I've never had to worry about that, but this is anything but a standard aircraft.
I have a feeling that the maiden flight will be a real nail biter.
Jack
