RCU Forums - View Single Post - RichModels Works LTC ARF's
Old 11-19-2005 | 01:45 AM
julio cavazos's Avatar
julio cavazos
Default RE: RichModels Works LTC ARF's
I put the tank like the instructions said , what i notice was that there is a gap between tank and wood, so i add some sticky foam to fix and to avoid engine mounting screws damage the tank( that already happens to me once) and a rubber band, the instructions does´nt mention the rubber band but, the wood shape seem that it was design to that.
I cut about 1 inch of the rod, so the nose goes down a little, that i think will help in to not to lift the nose to much in take off and not to scratch the prop.
I didn't add the nose weight yet because I'm waiting 2 servos from horizon to finish airplane.
For the prop i put a 11x6 11x7 pusher APC nylon prop, What i know its that this line does´nt broke when hits , just scratch or sand the edges,
Regards,
Julio
