RE: YS 63 Problem
Two things to try: 30% Coolpower Heli fuel, or pull the plug element up out of the cavity about .030" with a #11 blade. Either makes the plug run hotter.
Make sure both valves are set at .003". If too tight, the valves leak off compression and won't keep the plug hot at idle.
If neither works, send it.
