jongurley
your scale should be better than my old old one that works to give a good estimate
tip stalls? on landing or 3d?
Is your tail bolted on or glued?
when putting the plane together did you have to run to Andy's Hobby Corner to get more than one or two boxes of 6/30 minute exopy?
Did you put larger wheel on the landing gear?
Did you buy longer harder grade bolts to put the bird together?
Did you use heavy gauge 20 or lower wire to put the electronis in the bird?
Is the bird laterly balanced?
Did you add much/any extra wood to install switches/battery?
Did you glass the plane anywere?
