RCU Forums - View Single Post - Need help! replacing a G23 to a big lift
Old 11-09-2002 | 06:39 PM
Rodney
Default Need help! replacing a G23 to a big lift
Yes, you will probably require about 3 degrees of right thrust and maybe an equal amount of downthrust, especially if you have a high wing plane. The Walbro carb lets you put the fuel tank anywhere you like as it has a built in fuel pump which works very well. As mentioned above, the G23 is very economical, you will probably get two to three minutes run time per ounce of fuel.
