RE: Quadra 42?
Stick a popsicle stick through the ex port till it touches the cyl on the oppositeside. Turn the crank till the piston pushes on the stick enough to make a mark on the stick. ,35 is 1 7/16 bore. If it measures bigger than that ,it's a 42. I forgot what the 42 bore size is. Externally, they are identical.
