RE: variable exaust nozzle
Hi renaud,
a variable exhust nozzle on our turbines makes no sence at all. Reason is that the variable nozzle in real jets is used to compensate the gas extraction while the afterburner is launched and to keep the flame inside the turbine.
Doing this with our engines will cause a "block" of the hot air which will then reduce the thrust and raise the heat.
Andreas
