RE: What Tools Will I Need?
Tools! Didn't Skirkham ask about tools? How'd we get off into the ARF vs KIT question, again?
While I have a Zona saw and had an X-Acto saw, I use a real live genuine dove tail saw much more frequently. It is an accurate and precision piece of equipment I would feel necked without. Go to a hardware store and buy or have them order you one if they don't have it.
I regularly use my Pin-Vise.
I also make very good use of a combination square or tri-square (the kind which has both a 90 and 45 degree edge and will slide on the rule). I use this for marking, checking and cutting square corners, cutting straight cuts to 1 foot in length and to measure control surface throws.
I have used every type of hinge slotting tool there ever may have been and finally broke down and bought Great Planes Slot Machine and I really love this thing!
Maybe most important is a complete X-Acto knife set, the kind with the three handles is adequate.
You don't need to have every tool you will ever use before you start a kit. After 20-30 years of being in this hobby, you will still be adding tools as you go along.
