ORIGINAL: DaveB
I use the same arrangement as does Piper Chuck, with one exception. I use a fuel line and a clunk for the fill as it will hard to empty the tank without a klunked line.
Not at all hard, just make sure the nose is pointed a bit down. The tubing to the corner will let you drain the tank better than you can with a klunk.
