ORIGINAL: tkg
I think you have a glitch in your "check the timing setup" a BME won't run 6300 RPM with the timing set at 5 deg BTDC.
ORIGINAL: krayzc-RCU
Tim_Indy
i put on the C & H degree wheel the timing was at 5 degrees. i reset it the timing to 28 degrees and talk about a kickback/backfire in the exhaust on choke. This baby is in bad shape (C & H). I will be converting over to falcon after today. I did not even want to reset it to back were the engine would run once it kickback i packed her up and took a plane to the field to maiden flight....
