RCU Forums - View Single Post - Hinge line and control horns
Old 11-22-2005 | 10:17 AM
stek79
Default RE: Hinge line and control horns
Hello CG,
as Bill said this will affect throws: I suggest to you to fix it (in case you have this problem) working on the linkages stuff and NOT working with radio programming.
I say this because not only is best to adjust things mechanically if we know the problem, but also (and more importantly) you almost can't get equal throws working on radio programming if you have a unsound mechanical base.
On this topic very good infos can be found on Troy's article at central hobbies site, click "Informational" on left menu. You will find a serveral part well written article on control linkages.
