RCU Forums - View Single Post - installing top hinge
Old 11-22-2005 | 10:18 AM
leviva
Default RE: installing top hinge
First of all make the slot for the hinge at an angle down, so it doesn't touch the top of the surface. meaning the hinge when inserted makes an angle downward. I make a groove in the leading edge of the surface and in the trailing edge of the stab (for the hinges center) so there is no gap at all between them, and I also use some covering to seal it. make sure the hinges center doesn't stick out of the top of the surface
