RCU Forums - View Single Post - BME-100 kickback issues
Old 11-22-2005 | 02:38 PM
  #72
Geistware
My Feedback: (16)
Default RE: BME-100 kickback issues
OK, I know how a 2 stroke works, so you guys are saying that the advance is set to max and the ignition unit retards the ignition advance from 28 degrees at idle and 0 degrees above 4000rpm.
I was under the impression it was the other way around.
With this said, if the advance/retard fails, then the engine will still run but will be hard to start.
