RE: Hello! Which hull?
yess the prop has a big diffrence on your boat the firt 3 bladed prop will not work on a 54o motor it does not have the right pitch on it and its big ( i think) the 2 bladed prop is the best bet and when you put the surface drive on the boat if the boat is sitting in the water you should be able to see the prop and some of the driveshaft
