RCU Forums - View Single Post - Which brush less motor?
Old 11-22-2005 | 05:13 PM
raz54
Default RE: Which brush less motor?
Well the first test was sure a bummer. It was so slow it didn't even activate the radar gun (10-200 mph). I think the prop is too big. It says 25 mm but measures almost 28 mm. I might try filing it down to 25 mm plus I forgot the esc is set at a low setting. If those don't work I might have to get the higher KV rated motor after all.
