RCU Forums - View Single Post - 5014dps 14mz lockout problems
Old 11-22-2005 | 11:34 PM
dragoonpvw
My Feedback: (7)
Default 5014dps 14mz lockout problems
I am in the process of preparing my 112 inch 3w Mustang for flight. Before I go ahead I would like to hear a little more about the lock outs experienced with the G3 receiver. I would expect that the planes in the Tucson shootout would have dual receiver set ups, did the lock outs happen in both receivers at the same time? What type of setups did the pilots who experienced the problem have in their planes? How did they determine a lockout if they did not crash? the split plane method of installing twin receivers is common so if the pilots just lost one half and had control response reduced seems likely but I am grabbing at straws here. I need more information to work on a solution.
I am planning on two G3 receivers with an emcotec DPSI twin, I will of course go through the plane as well as is possible to reduce unwanted rf interference but if the receivers were locking out simultaneously then that would seem to be a problem that dual receivers would not help.
Secondly you recommend reducing the length of the antenna and range checking, if the range is not reduced then the situation will be helped. If the range is reduced though will Futaba repair/replace the antenna for free? that would only seem fair. If that is the case and your answers here lead me to take the step towards changing receiver length then I am thinking about leaving my primary receiver at the full length and reducing the length of the secondary receiver as a safeguard.
Whether both receivers locked out in a plane at one time is an important question and should be answered asp, if that is the case then the problem is sensed throughout the aircraft, if it is not the case then it is localised and obviously due to an idiosyncracy of the position of the reciever.
This aircraft like many that will be using your top of the line equipment will be into the tens of thousands price range when complete, even more important is the safety aspect, it will be big, heavy, powerful and potentially dangerous. Flight testing should be in two weeks, I would hope to have an answer to guide me in my installation on this plane, at the moment I could probably drop down to two 9 channel receivers but that is not something I am planning on at this time.
I have had no problems as far as I can tell so far with the g3 and have been flying it hard on a 31% edge, I did however have a glitch (wing dip) on approach last landing and scraped a prop, the plane did not go into failsafe though and an aileron servo was missing a few teeth in the center, the obvious culprit. Did all the problems exhibit going into failsafe or were there examples of glitches with planes not programmed with FS and how bad were the glitches?
I know that this seems like airing your dirty laundry but as you have acknowleged a problem, surely you must see the necessity of giving us as much information as possible.
Thanks for your time
Paul
(edited the spacing so we could read it. did not change content..)
