Lt-40 wing build help
I am building the first half of my first plane. I have glued the top spars and the leading edge to the ribs. this may be a fatal mistake but here it goes. I was not thinking. After gluing on the top spars I noticed that the spars stick up a little above the rib grooves(1/32" or less). Obviously it is to late to take them off to change is this a problem or what can I do to fix the problem. I did not see in the instructions if you are to sand the entire wing or not. I am sure that you could disfigure the wing by doing this. [X(]
Thanks for all of your help in advance
