RE: Lt-40 wing build help
The spars should stick up above the ribs in the middle where the sheeting goes. The ribs out from the sheeted portion should line up with the spar, at least they have on every Sig kit I've built. Hope you remembered to install the shear webs before you put the top spar on. You may have no choice but to sand the spars down. Glen
