RCU Forums - View Single Post - port timing
Thread: port timing
Old 11-23-2005 | 05:12 PM
dbryan
Default RE: port timing
Piston port intake will give high top end power but, as you have found, at the cost of mid and low end. A good reed setup will have the best overall performance. The trick is to contour the interior of the reed box to minimize turbulence. Most don't realize they are dealing with supersonic air flow inside a two cycle.
