RE: Grrrr... what the hell
The savage is the strongest monster truck on the market!!and the new ss 4.6 kit is the top savy just add a rrp steel spur cb/ a good radio set up and thats all the upgrades you'll need!! integy is ****!!! we stopped stocking integy crap 2 yrs ago!I have 2 savage one had a mach 26 15/52 gearing 2speed trans and i beat lst's 21 t -maxx ect... tune your engine!!! adjust shift points with the 3 speed you will kill a stock lst alot of problem stem from inexperiance all models break but there are tricks to make em last longer always shim your diffs!! Ring n pinion need shims as do the spider n bevals 13 gallons 2 engines later on the stock diffs
