RE: 30cc Homelite conversion??? HELP !!!!
I have an Echo GT with the same setup, these engines do not have a prime pump, only a blade type choke in the air cleaner. The best solution to this problem is to install a larger carb set up for a pump and add a return line. The carbs without a choke are a pain in the ---.
