RCU Forums - View Single Post - port timing
Thread: port timing
Old 11-23-2005 | 11:25 PM
The_Pipefather
Default RE: port timing
Usually port timing for a particular engine works in conjunction with port area....so we have a parameter known as time-area which determines the port ability to flow within a given time period.
Having done the time area numbers on my 34cc engine I used the following durations (for a power peak of 7500 rpm)
Exhaust: 160 deg
Transfer (twin transfers only): 125 deg
Intake(piston ported): 160 deg
The factory timings (for stock power peak of 5600 rpm) were
Ex: 140 deg
Transfer: 110 deg
Intake: 135 deg.
My timings may seem radical but are necessary because I am also looking for piston & ring life. I could go wider on the port but that then I would be crossing safe limits of about 65% beyond which ring life reduces.
If you have a rotary valve setup then you can safely go to upwards of 210 deg before experiencing significant blowback. This is what I have found on my 125 cc engines. Using a pipe with a rotary is almost always mandatory if you are going to open the port very soon though.
I dont know much about reed valve engines havent worked on them.. Bryan, if you are going to retrofit a reed valve from a larger engine to a smaller one (which is turning many more revs than the larger one) what are the guidelines, or thumb rules if any?
