RE: South Central Basic Bootcamp
Jarrod, be sure and use low rates when you fly IMAC. Tom's directions as to the number of degrees of throw should be approx 13-14 degrees, rudder about 25-30 degrees and aileron as much as you like. Be sure and use expo on all control throws.
BTW Guys, I will bring my degree meters that Duane Cox designed and Don's Hobbies now sells. The degree meters are NOT the thingy with the clothes pin on it, they are much more accurate than that!!
Bobby
