Saito
Dan, have you checked to see if either one of the push rods has jumped out from under its rocker arm? Most likely the intake. Or the intake tube may be out of alignment and be leaking air. Just a couple of thoughts. If the intake tube has become dislodged take the screws out of the carb and lower the carb a little to put it back in.
