RE: 2 Stroke vs. 4 Stroke
Both these glow engines should work good for you. Forget gas for small 3D planes unless the wingarea is HUGE or if you need the extra weight for the balance. Reliability should also be equal between these two if you follow the engine manual regarding the settings and fuel requirements. IMO the modeller is responsibel if an engine is not reliable unless you go and buy an cheap low quality engine with known carburation problems. Just my thoughts!
