RCU Forums - View Single Post - Seawind and Retracts
Old 11-24-2005 | 10:25 PM
Hookedonairplanes
Default RE: Seawind and Retracts
Ok ok ok. You can not go from land to sea and sea to land. What is the problem here??? If the retract when installed are water tight, then can the retracts be used? Or even if they are water tight, they still can not be used? What is the real story? I am getting my Seawind next week and I will know better at that time. I have also ordered the retracts and expect (somehow) to use both. Well...is there any way or answer to use the plane for land and water in the same flight time?
Roy
