RE: prop diameter vs pitch
Have you ever sat on a bar stool that spins around 360 degrees, and spun your self with your arms near your body and then away from your body ?
Well if you didn't , the speed of you spinning lessons the further out you stick your arms. The closer you bring them back to your body the faster you begin to spin.
Apply this example to a prop. the bigger the diameter = less rpms.
