ORIGINAL: mikmaxx
I whant to go straight to a scale jet because im on a budget and cant afford more than one jet.
dude, you are way out of your league, and are not going thru this properly.
you are on a budget? if I have read all of your posts previously all over RCU,
you dont even fly? you are looking at sims, and dont which one?
you have a P40, that you have to wait till Xmas. it is a smaller one, that is
GLO powered, not gas. big difference, as its a small prop plane, and not a heavy
wing loaded Warbird.
I sometime will go to a turbine. I have alot of heavy wingloaded warbird flight time.
but I am not going to jump straight into a SCALE jet, as that is what I would like to do.
BUT, that is not the proper approach here. If and when I decide to, I may go with one
of Pat's Dv8R's or something else similar. who knows, but I wouldnt attempt to go out
and jump into a Super Hornet just cause I know how to fly a warbird?
a budget you say, you better stick with what you have, because you arent going to afford
the jet stuff
**edit** I see Jason just posted above me about going to jets from small warbirds.
there are exceptions to the rule, but you have to put in your dues before you want to
think about jumping straight to a jet, without even mastering a trainer, let along a warbird
