RE: Help!!!...G26 Carb' problems???
On my 2nd new G26 the spacer block was upside down and the pulse hole was covered. I could get it started with an electric starter. but it would shut down past 3/4 throttle. Would not idle.
Yes there should be a gasket between the carb and spacer and between the spacer and the motor block.
It is a great motor and you'll be pleased with it when it is running right. Brian
