RCU Forums - View Single Post - PHA-300 without main motor
Old 11-26-2005 | 04:56 PM
credence
Default RE: PHA-300 without main motor
Mixing works between the mains and tail. Since you don't have a motor plugged into the throttle lead on the PHA-300, there will be no mixing between them. Basically, if you want to use the PHA-300, you can't use a brushless motor.
