RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 11-26-2005 | 06:30 PM
  #1347
ptgarcia's Avatar
ptgarcia
My Feedback: (36)
Default RE: E-FLIGHT BLADE CP
ORIGINAL: Lammy1000
Should i be concerned about the roll/aileron trim being near the extreme left for steady hovering? I'm using the 8t motor, 3s 1320mah lipos and the flat blades are close to needing replacement. Thanks.
Lammy1000,
Make note of the attitude of the swashplate, then disconnect the links, center the trims on the transmitter, and adjust the links so the swashplate looks the same as before. When you're all done you should have a level swashplate. Good luck!
