RCU Forums - View Single Post - prop diameter vs pitch
Old 11-27-2005 | 07:28 AM
Dr1Driver
Default RE: prop diameter vs pitch
Most models fly at 60 - 90 mph wide open. Most glow 2 cycle engines are happy turning around 12,000 rpm range give or take. And so the 6 pitch is the most common for this combination.
A glow 4 cycle revs up a few thousand less, so 7 and 8 pitch is common for those. Larger gas motors turn even slower, typically 6,000 to 7,000 rpm, so 8, 10, and 12 pitch are common.
Multiflyer, what you say is true in generalization only. "Most" is nowhere near "all", and I'm not sure "most" can even be used as a generalization. In fact, there are so many types of engines, props, planes, and flying styles, I'm not at all sure a generalization like this can be made. Each engine/prop/plane combo is different and has different requirements, depending on how the pilot wants the plane to fly. Have you ever used a radar gun on an R/C model? Most do not fly anywhere near 90 mph. All engines are different and each has a different optimum RPM. The RPM requirements will change from plane to plane. I have a Webra Speed .32 and an OS .32 that are both happy turning 14,000. These engines use 10 x 4 props. I have a Zenoah G-23 that is happy with an 18-6 prop. 4 stroke glow engines can turn larger diameter props with less pitch, and are often used for this purpose.
True, there is usually a good base for prop diameter and pitch to start from. After that, experimentation is the only way to achieve the best combo for a specific plane's use and the pilot's flying style. The pitch and diameter may go way outside your figures, and even the manufacturer's recommendations. Blanket assumptions just can't be made.
Dr.1
