RE: Quadra 42?
Single piston ring, 35cc or later model 40cc or 42cc. I have the 35 and 40cc version both early style. Is there a black wire coming from under the flywheel opposite side of the carb? If so then it's a point type ignition 35cc. If not it will most likely be a newer 40 or 42. A bore measurement will confirm this.
