RCU Forums - View Single Post - TF Contender
Thread
TF Contender
11-27-2005 | 01:03 PM
146
Safebet
My Feedback: (
12
Sep 2004
654
Diana, TX
RE: TF Contender
This build is going very good, so far. I have attached two more pics. I am still waiting on the 2 pcs. of 48" basswood for the spars for the wing. While waiting I decided to assy. the fuselage, optional wingtips, etc.
I assume when I glue in the firewall that I won't have to make any adjustments to it. I will be installing a .61 OS FX. I have purchased a Sulliavan Dynamount Soft Motor Mount.
The engine is dampened with rubber mounts to eliminate a great deal of vibration.
With the stock muffler I can swing the engine 90 degrees and it will clear the bottom of the firewall only if I lower the engine down from pre-marked holes by about 1/8". Do you think this will affect the thrust line enough to be detrimental?
I am a little concerned about muffler ground clearance. The muffler will be running right in line with the R.H. bottom seam of fuselage, so I think it will be ok. It will be blowing fuel underneath and between the main gear. I will not make any decisions until I am further along, wing built and mounted and gear attached.
I am depending on you guys to help me if you note anything either in my comments, pictures or just from your experience.
Jim
AMA 821369
Reply
Like
Safebet
View Public Profile
Send a private message to Safebet
Find More Posts by Safebet
View iTrader Profile
