RCU Forums - View Single Post - Tightest ABC Engine I've Ever Seen
Old 11-27-2005 | 06:30 PM
buzzingb
Default RE: Tightest ABC Engine I've Ever Seen
This isn't good for an engine. Do like someone earlier suggested and use a heat gun to warm up the engine before turning it over. This will expand the cylinder and give the piston a little extra room to break in and size itself to the cylinder as you run it in. It can cause piston & rod damage so don't take a chance and use this simple device to give the engine a chance.
