RE: Engine Orientation
When engines are entended to be mounted inverted, the motor mount is somethimes positioned a little higher on the firewall so the engine does not stick out the bottom to much so when you spin it 180 degrees you might want to take a look and see if it needs to be moved down a little while still maintaining the center line location. It may be sticking up a little higher than you would like.
