RE: Reflection Biplane FlatOuts rolls on takeoff
you could take the motor out then put a small washer or two on the farthest right bolt(if you looking at the plane from the front)to ry o give it some right thrust that might help and if it doesnt and it makes it worse then you can always take the washers off ...............
