RCU Forums - View Single Post - WYL Series Walbro Suitable?
Old 11-28-2005 | 08:21 AM
bdtsr
Default RE: WYL Series Walbro Suitable?
The rotary barrel carbs have a very stiff return spring that also holds the barrel in position. The barrel raises as the throttle is opened which also raises the metering rod. They seem to offer better throttle reaponse because the fuel is metered across the entire range. The stiff spring I think would creat battery drain problems.
