RE: Plug Reading Question
I found better starting, overall throttle response and stable running throughout the envellope at a slightly rich mixture.
Leaner in theory may be better, but sometimes makes the engine a bear to handle, and not better behaved in flight. It also increases exhaust temperature considerably, which puts a heavy burden on the header to silencer coupling.
Also, the margin to a fried piston is so much smaller when running at optimum lean mixture [:@]
